Honda CGL 125 carb help?
crqcycles
Not a lot of cafe's down here in Mexico...
Hello everyone!
I installed a high flow air filter on a Honda CGL 125. Since the filter allows the carb to get more air, I assumed the mixture would be lean and that I would need bigger jets.
Somehow, I was WRONG! With the filter installed, the mixture is extremely rich (the sparkplug is black and wet). How can his happen? What should I do to run the filter with no problems? I am currently running the stock jets (102 main, 38 pilot)
I really need some help with this!
Thanks for reading,
Juan Fco.
While I'm not familiar with the 125 (CG, CB, whatever), I would think it is more of an electrical issue. That would cause a weak spark and therefore a fouled plug.
The carb is a manual carb (throttle cable lifts the slide), correct?
I'm running a pod on my CB125. I had to go down to an 85 main, from the stock 98 to get it to run right. I had the same problem as you to start with. When I first tried the pod with no jetting changes, the bike would only get down the road before it started to foul up the plug and misfire.
My understanding is these small engines don't run so well without the airbox. I think the airbox is designed to set up a sort of resonance, which helps force more air into the engine. Although I'm not really in the know about the physics of airboxes. You should be able to get it to work though, probably not as well as the stock set-up, but sometimes you have to sacrifice function for style ;)
Many times the rubber snorkel that connects the airbox to the carb is in itself a velocity stack. the carbs are tuned to how the stack will create a bit of a vortex as the air enters the carb spiraling through the center of the bore. When you remove that it just becomes a gaping hole and suck air in from all around it.
It's definitely not an electrical issue; the bike is new (2012) and everything works perfect! (except for the carburetor with an aftermarket filter) And yes; it has a manual carb.
What size is your pilot and what size was the original?
Today I tried to connect the filter to a radiator hose (from a car) and to the carb. Strangely it worked perfectly! However, I had to run a super long hose because when I cut it to accomodate the filter it stopped working ok. I tried a longer hose and good again. You can see the pics in my thread!
That actually makes sense! It is the best explanation anyone has given me!
If I install a velocity stack instead of an air filter, in theory it should work ok?
Thank you very much!
No changes to the pilot or any other jet settings. In saying that, the jetting is not perfect, but it runs ok, and doesn't foul plugs. It's a 1973 with 45000km on the clock so I'm not expecting a perfectly smooth runner. Small bikes like this look great with a minimalist look, and the airbox adds a lot of bulk (they can weigh a bit too). Whatever you're running, velocity stack/pods, you will almost certainly have to make some jetting changes. With a bit of perseverance, you should be able to get a brand new bike like this running super smooth!
If you try that velocity stack, do report back and tell us how it runs. If it does the trick, I might consider putting one on my CB.
