Honda CL350 Carb Help
danielsb
Fellow vintage Honda enthusiasts - I am in search of knowledge.
During the process of disassembling my 1971 Honda CL350 Keihin cv carburetor, I removed the choke and throttle butterfly shafts. In the bores, where those shafts sit, there was a gasket-type of material that sat in a machined grove (see pictures below). There were three places where I found this gasket - both sides of the choke butterfly shaft bore, and on one side of the throttle butterfly shaft bore. The material was falling apart, so I removed it.
After doing a little research, I believe it may have been a mistake to remove the shafts and gaskets. The exploded view of the carb in the Honda parts manual does not show the butterfly shafts removed nor any gasket material.
Does anyone have any insight or experience with this? I'm considering trying to use rubber O-rings in the place of the gasket material, but I'm open to other considerations...
Thanks in advance.
Yeah they are felt orings and as far as I know no longer available from Honda :/
Hmm... felt O-rings. That definitely describes what I pulled out. Any thoughts what to replace them with?
I've got to believe with all of the Honda 350's out there, someone would have come up with a solution...
Here ya go bud:
Discussion:
http://forums.sohc4.net/index.php?topic=67160.0
Parts:
http://www.motorcyclecarbs.com/search.cfm
Sounds like the "U-rings" work well also. Those may be available locally.
