Hi guys, my name is Niels and I'm from Holland. ;D I've got a Honda CM400 (full build caferacer). The flow of the head is optimized and we fitted a 450 cylinder. The original carbs (and intake) are 36 mm Keihin. The Mikuni VM30 and VM32 are used as a upgrade for the CM/CB 400 / 450 (i've got two VM30's). The difference between the carbs 30+mm and the intake 36+ is huge. This could result in pour flow/gas handling. I believe the 34 or 36 mm Mikuni's are overkill for the CM400/450. But I'm not sure.
Some tell me to use the VM30. Others to buy the VM36's and build a special exhaust. I don't know what to do or can be done.
Can anyone help me with this issue? What is the best option?
Thanks!!
and I'll soon open a project to show my build.. inspired by some projects I've seen of some of you guys!
Thanks!!
