Honda Electrical Woes
budrecki1
A diamongd in the rough
Day 3 Hi guys ,
I have a couple questions My started motor is always operable even when the key is off can this be an issue with my bike not starting or is this normal for a Honda? and is there a way I can direct wire my bike to hear it start once? Sorry if these questions are dumb but "we" are a work in progress Thanks in advance and to everyone who has given me ideas . I have not found any issues yet except the starter
Hey,
I split out this post into a new topic as to avoid cluttering up the 101 thread with specific information.
First issue - starter motor works with the key off - Trace the wires from your solenoid. Specifically the black wire. Make sure this is connected to another black wire in the harness and not connected directly to the battery's positive terminal (as I suspect is the case).
Second issue - direct wire the bike - Run a wire from the positive terminal of the battery to the black/white wire(s) from the ignition coils. Ensure that the battery's ground strap is secured to the frame and is free of corrosion.
I have a black wire with a battery hookup going directly to the + side of the battery(from the selinoid. I also have a red&yellow and a green & Red wires off the of the solenoid to the wiring harness . There is also a tapped up green & red wire with a male end not connected . No black wire to the solenoid ..???
Sounds like someone made some changes, then? Possible that the solenoid is from another bike?
Green/red wire is used by Honda for the neutral light.
Anyway... the idea is that one wire on the solenoid gets power and the other wire leads to the starter button which, when pressed, completes the ground and triggers the solenoid.
Basically, make sure the yellow/red wire is connected to your starter button OK and then take the other wire coming from the solenoid and plug it into a black wire on the harness (hopefully there is a spare connector somewhere nearby).
Sonreir, the 1976 model year did not ground the solenoid on at least US Honda's. The DOT required headlights to be on at all times. So Honda deleted the On/Off headlight switch entirely. The Starter button is fed 12V from ignition, and is a double throw switch. Released, it supplies 12V to the headlight. when depressed to start, it disconnects the headlight and supplies 12V to the solenoid. Before that, you are are correct, they ground the wire from the solenoid to complete the start.
