Honda engine mods
Starfire
I have heard that Honda 360 cylinders will fit on a 350 engine. I have also seen people put 450 pistons in a 360 engine. So my questions is this, how far can you bore the 360 cylinders and will they actually fit on the 350 engine? Is there any difference aside from bore between the 350 and 360 cylinders?
Also, will the 450 cylinders fit on the 350 engine and will the head fit in the frame? Will the 450 head fit on a 360 cylinder?
The stroke on the 350 and 360 is the same (50.6mm) but the 450 is longer. 450 pistons (74mm) in a 350/360 engine makes a 434cc motor. I want this.
I know there are big bore 450 kits, how big can a 350/360 cylinder be bored?
The stroke on the 350, 360 and 450 is the same (50.6mm) so 450 pistons on a 350 engine makes a 447cc motor. I want this.
Also, are there big bore 450 kits? If so how big are they and can a 360 cylinder be bored to that point?
The 450 head (from the Black Bomber right up to the 1974 CB 450) will not be compatible with the 350 engine...The 450 is a double overhead cam,whereas the the 350 is a single overhead cam design. I can't pretend to know the answers to your other questions,but I am sure someone else can impart their wisdom.
I don't see how the head design implies incompatibility. As long as the drive ratio from the crank to the cams is correct and the chain is properly tensioned it should work. Problem is if the studs fit the cylinders and if the head will fit in the frame.
Does anyone have the cylinders out of a 450 and/or 350 who can measure the spacing between the studs?
cam chain set up to run a single cam likely not tthe right size for a twin cam. I can't see these jugs being interchangable. honda changed so many aspects between those motors.
even if you can make it work the increased power to hassle ratio is too high in my opinion
why not just bore out the 350 cylinders?
my understanding is that the only reason the racing pistons are 362cc is because that is the maximum allowed under the class rules, and that the cylinders can be further bored to somewhere between 400-450cc. obviously if this was possible and you did this, it would be far beyond what the engine was designed for, and you would be making compromises in other areas.
Powroll did make a big bore kit that pumped the stock 325cc to 425cc. The crankcase top needed to be bored out to fit the cylinder sleeves. Racers use the pistons from a Kawi GPZ305 for performance gains.
How does a piston that much larger match up with the head? Are there additional modifications that are required to the head to make it all work?
