Honda Hornet 599 Retro-Mod
Made a mount for the front of the seat out of plastic then cut a rectangle hole in the frame for it to slide into. I mounted a couple of nuts tacked to a bar to the back inside of the seat also made a mount on the frame to secure it with 2 bolts. I glued several layers of foam to the base and shaped it with a knife and different sanders. Just need to get it covered.
I dismantled the bike so I could start painting all the parts. Since the original Nighthawk was blacked out there was plenty to paint and powdercoat. I sent several parts to PC. I painted the engine and frame as well as some parts. I wanted to black out the forks but anodizing wasn't in the budget and I was concerned that paint would easily scratch so I had this idea to used large shrink wrap to cover them. It work pretty well only had to paint a small section on the fork to allow it to pass through the triple clamp. I also installed heavier springs and oil in the forks to stiffen up the front end.
Going back together lots of stuff blacked out. Bodywork going to paint this week. Hope to have it done before the end of the month.
I took care of some details while everything is at paint. Added grips, levers and mirrors. Did some mods to the chain guard. I also got my seat back from upholstery.
Back from paint and all back together. Also took care of some details made filler panels at the rear of the tank, added a plate under the tail to help protect electronics and act as a plate mount. I used 2 led bulbs hidden at the bottom inside corners of the tail light for turn signals. One thing nice about using a more modern bike is it fired right up and runs like a Honda.
One of the hardest things to do in a custom bike is to match different style elements and that's twice as hard when they come from a completely different era. You have done an excellent job of making that work and it looks really good.
Congrats
I could not agree more - I love the Nighthawk in its stock duds but you've really broken the mold here. This is the best looking Nighthawk (well, Nighthawk mash-up) I've ever seen. Bikeexif needs to know about this ride. Congrats man, absolute belter.
Thanks guys for all the compliments. Here are a couple more pics of the bike.
