Hondazuki XLRM250 Trans-America Hell Ride
Nearly a perfect fit for a CR rear fender. I'll just need to move the stock frame mounting brackets for the rear turn signals...
Started cutting shit up today...
The top shock mount wasn't exactly right, so we cut a section of the top tubes away under the seat and cut the tail of the spine to push the mount forward to it's proper height and angle.
Removed the lower engine mounts.
This spring and shock is shot, so I worked out a deal with Kanticoy (instagram @sadhandie) for a sweet rebuilt jawn.
Separated the down tube, added 2 3/4" of tube and put an angle forward to make room for the front XL250 engine mounts and leveled the cradle back out...
Time to fit the CR rear fender...
I cut the cross members and removed the hoop so I could spread the seat area. Took a conduit bender and curved up the tubes behind the stock shock mounts. Cut off the back of the mounts and shaped to fit the fenders profile. I'll fill the gap, eventually. I'll also weld the hoop back on and fill the space in the seat area.
Tune-A-Fish said:
When we gonna fill that air gap between the main and sub frame?
Probably hold off until the rebuilt shock gets here to make sure I clear the reservoir.
No. Same specs, but it's a Kawasaki and has what looks like a high shoulder.
the bikes coming along awesome :D
you all are gonna have an experience to tell stories about fer the rest of yer days
i seen lights mentioned,man if you really want something super bitchen get a helmet light,something with a super bright spot focused carefully
its a great feeling being able to point and look ,i rigged up a halogen but theres all kinds of led units now i figger
Tune-A-Fish said:
You can get a brake light for helmets now also, seen a few in Michigan last year.
that is a fantastic idea 'specially for those unfortunate enough to live in close prox to millions of caged drones mindlessly carreening about, ie any usa metro region/ city
While texting >:(
Tune-A-Fish said:
While texting >:(
there is advantages living in the poorest county in the state no cops,only 2 sherrifs on duty for entire county ,everbody unemployed hence nobody driving to work neather
the whole south state for the most part IS the people of walmart,pretty decent traffic snarles there on occasion too,like when candy-koated korndawgs are on spayshul
Our Home depot had to fire the mini doughnut lady because of the fights over who was getting the next batch :-\
Since I'm waiting on the new shock to arrive and piston rings for the motor, I'm shifting direction to the motor mounts. In order to get chain alignment, I had to shift the motor right about an inch. It actually works out nicely for the left front/upper mount as the motor location lines up with the frame location. I bent up a new crossmember to clear the shock and fitted the left rear/upper. I'm tying onto a sleeve I machined for the swinger pivot bolt...
Also: How the hell can people be so good at welding in tight spaces? I guess I should be tacking everything and doing final welding on a table. Fuggit
the cs looks way way out of place almost as if the chain will be getting into the bottom of the pivot
you will have to run a spring loaded tensioner but if it just stops on the bottom of the swinger it cant very well manage the huge variances in chain tension
cs is way too high and too far from pivot
