Hondazuki XLRM250 Trans-America Hell Ride
M/C hell is when you order two off eBay as good and they're frozen, so you return one and buy a rebuild kit for the other. But, because China your All Balls rebuild kit isn't to spec so you have to machine it to spec with your American lathe...
Tune-A-Fish said:
Bottom plunge backards on the cussom turned one?
Yeah, that's the other thing they did wrong. It's been flipped before install. Good eye.
adventurco said:
Nice..I have had good luck with stretchy upholstery vinyl. Is that from SailRite? If not, got a link?
Got it local. A place right around the corner. Stretchy makes it much easier to get it right, for sure. I've been meaning to check out Sailrite. I've watched a bunch of their tutorials.
That looks neat and tidy Eric. Hope my GL cover is half that nice LOL. I got a leather just a tad lighter than your vinyl.
It's got a couple of tune issues I'm trying to sort out. Runs beautifully in mid-range cruise, but it's fouling plugs and backfiring through the carb off throttle and during idle. Ordered advancer springs from MikesXS and cut a coil off in the meantime. I'm going to run through the carb again for good measure. We'll get her tested again today.
Edit: Changed to another advancer altogether. Now we're just left with the backfiring through the carb at idle. Need to sort out what appears to be a lean idle.
Leak down test and compression 165 and steady.
And done (at least with the making it run part)...
https://youtu.be/GH-urhOdtng
So when are you going to have a shootout with the other ADV bike on here? Kinda like what motocross action magazine does.
His day is coming. Don't you worry. Loser swims with the snappers.
Another quick little update to close a pretty productive day:
I've been sitting on this freshly rebuilt Fastlap Kawi shock. I couldn't quite make it work, so I stole the spring and held on to the RM shock with plan to rebuild. Not really happy with the RM shock, I decided to rethink the Fastlap. A little measure made it clear it was in the bottom clevis...
Kawi left/RM right.
They both thread exactly the same. And the size and shape of the RM clevis is important to the rear end function. I machined the spring cup to accept the RM clevis and now we have a wonderful rear suspension. Riding showed significant improvement. I did, however, have to alter the frame under the seat to accept new shock and clear its reservoir...
You know now why the cut out is there? Also I took the res and flipped it over to the left air boot side side and that gave me room to run the exhaust through the frame on the right lower:
//uploads.tapatalk-cdn.com/20160604/a305cb71ab4d5987c3a0ad3baa2adb5a.jpg
