hone your motor!
chris73cb175
so i stripped this motor and plan on de-glazing the cylinders. i was just wondering if the tool i got would work due to the length of the blades. most honing tools are really big due to use on cars or don't expand wide enough for my motor. i found this perfect one goes from 3/4 to 2 3/4. the only thing i'm wondering about is the length of the blades. they are about 1'' do you guys think its too short.
i'll be posting pictures of the update build tomorrow.
here is the tool from pepboys.
Before you use it, make sure somebody that knows responds! I think PJ said that the stones have to run the length of the bore for it to work properly.
I'd agree, honing removes irregularities and improves the flatness of the cylinder wall, if you use something with shorter blades, you can make the cylinder worse if you are inconsistent in how much time the hone spends in different areas, and you may end up with deeper grooves caused by the corners of the hone
the blade type hones are tricky as stated, see if you can find the ball type as they are pretty idiot proof.
Stone hones like this are not what you should use. Because of uneveness in the cyclinder they only hit the high spots.They should be used on newly bored cyclinders. See if you can rent the proper BALL hone. And make sure it is the proper grit and diameter. The cross hatch is also very important. There are great articles on the web about ball hones, grit,and hatch..Good luck..
Yep, they are short.
I could probably use them
If you can get the long version it will work, but wouldn't advise it unless you've had a lot of practice honing
Ball hone would be a better bet unless you have cylinder bore gauge to check sizing.
Knocking off high spots is a good thing, providing you can measure what you've done.
Honing picsics in my 378 build (665/667-Neighbors of the beast)
PJ
Many moons ago I had a snowmobile engine oversized(sunnen hones)and done with 3 stones,,to spec it worked fine(not me),,,,,,before I could afford to buy a hone, de-glazing was done with sand paper or emery cloth...whatever you could find in the garage. If you reassemble a old engine!!! (stock rings, pistons) scuff the cylinder walls so the rings will seat again.Short blade hone is what I use(to deglaze)....oil, slow rpm...and try to acheive a 60 degree cross hatch( never happens ::)),,,,,,food for thought, I blowed up a 9500 blizzard,,it locked so hard,the ring embedded a groove (spiral) into the cylinder wall,,,,,,,scuffed it out(3hrs later) installed a new piston.......no problem,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,then sold it :o
I was told along time ago by an old guy that the easiest way to de-glaze a motor was to get it up to about 3500-4000rpm and throw a palm full of Ajax http://en.wikipedia.org/wiki/Ajax_(cleanser) and throw it down the carby.
Now I have never done this. I have been threatening to do it to the old mans lawn mower as a test for a few years but being a mechanically sympathetic person I don't have the heart.
Warning: Take this post with a pinch of Ajax! I have been told alot of silly things hanging around in work shops.
Yeah, this isn't something I would openly suggest to anyone. Not even my worst enemy. If anyone does put Ajax down their carb, they deserve the results they will get for being lazy.
Get a rabbit turd or ball hone and scuff them up. It only takes a dozen passes + or - with the ball hone to break the glaze. If you are new to engines the best thing to do is get a book on small engines.(library's don't charge) I like the way old books in the library have pictures from the 60s and 70s showing how to do shit. All the information should relevant to what you are doing.
VIDEO HERE
Outboard hydroplane racers refered to something called "diamond dust"(circa 1950's) that was run through the engine to enhance performance..flat head factory harleys( flat track) were attached to large electric motors and spun for hrs with a special mixture??? to enhance break in.........Ajax is good for removing islands in the shitter ::)
Hone it, then reassemble, relube and ride. Running in procedure for almost any piston engine will be as follows:
* Adjust carburettors to spec and top with appropriate fluids before taking onroad.
* Use only 1/4 throttle and low revs for the first 10min.
* Second 10min use 1/2 throttle and medium revs.
* Last 10min, find your favourite twisties and use full throttle to redline in all (or most) gears. Include backing off the throttle from redline.
* Afterwards, be sure to ride gently for a few minutes to let the engine cool down.
* After arriving home, check all fluids and carburettor settings. A plug chop may be in order to determine precise jetting.
And there we have it. Thats how I run my engines in anyway, so don't take it as gospel. It has worked quite well for me so far though, and the 2 Aprilia RS125's I've done run in like this have gone quite well indeed. In a nutshell, the theory is that the fresh bore honing marks need to be there to help bed the rings in properly to the cylinder bore. If you do NOT use full throttle early in the engines life you will miss the chance to properly bed the rings in, and may lose performance when compared to an engine that has been run in according to the above.
Cheers - boingk
PS: Another note not to take this as gospel, but I do it and it works quite well.
thank you guys so much. i did a lot of reading and research on honing before i mess with my motor since its the only one. i have honed a motor before in class but it has been awhile.
i returned the tool i got. and just received the tool i initially wanted. here are the pics.
i got a 2 inch. i'll post a video when i get the rings in.
When it comes to tools, don't settle for something you didn't want in the first place. Just keep looking until you find what you want.
One of the main books that got me started into doing this crap was a book by Jay Webster called Small Engines Operations and Service.
Like I say get a book or a service manual from the library (its free and most of the old methods are still used today). Honing one engine is like honing any other.
thanks a lot i appreciate the help. i'll hit up the library down the street. and also i'll look into the book you are talking about. i have a few books about chevy motors. can't wait to get this thing going. keep you guys posted.
thanks
