how can i make these clip ons work
need4steed
Active Member
I was just given some 43mm clip ons from a triumph, but my forks are only 37mm on my Gl500. is there anyway of making these work, or am i just going to have to sell tham and buy ones that fit. Thanks
you could machine some spacers... if you have your own mill, that is. otherwise its not really cost affective... plus you might run the risk of them slipping.
i highly reccomend the adjustable clipons from roccitycafe... i got a set and the quality is amazing, plus they look cool as shit, and youll be supporting a DTT member =D
Rocan is right, the SAFEST thing to do is buy some proper size clip-ons. Probably get a good price for them on this site/ebay/craigslist and then pay a little bit for some from roccitycafe. But if you are dead-set on using them, you could try to shim them with something else and tighten the hell out of them so they don't slip on your tubes. The biggest problem would be under hard braking when not only is your weight pushing on them, but also the g-force of you stopping on them too (they would try to twist towards the headlight). If you had solid handle bars (drag bars?) that could stop the twist but in the long run it would be just safer and simpler to get some 37mm clip-ons
I would turn some 'shims' with a flange to bolt to fork pinch bolts (basically a split 'tube' with tab)
They may look weird though with large outside diameter.
PJ
I was able to machine some spacers to fill the 5mm space. i made them out of aluminum. I will get some pictures up soon, but i was able to make them work just fine. there isnt a worry about the slipping or moving. Thanks for the help guys. the shim idea was perfect.
here are the pictures of the shims and how they work.
