How can I patch up this exhaust?
krukster86
So when I bought the CB360t, it came with some custom pipes that the seller put on when he had the bike. He put on the thermal wrapped headers which are awesome and I have no problems with. The problem I am encountering is the black exhaust that the headers are attached to. He has drilled holes in the black exhaust and attached them with bolts (somehow) to the header pipes, and this kept the pipes on, but they were wobbly at best. After each ride, the bolts would be 1/2 way out and I would have to screw them back into place. On a recent ride, one bolt from each of the exhaust pipes came off. The black pipes are still on the bike, held on by 1 bolt each on the bottom, and supported by the centerstand when it is retracted. I am wondering what I should do to support these pipes.
1. Maybe fabricate some sort of bracket to secure them to the frame? Hard to do since I don't have a workshop.
2. Find someone to weld the pipes onto the headers?
3. Anything else?
Thanks in advance. Pics for reference below!
Looks like one bolt thru' and no washers.
If all you want to do is stop it wobbling around....
Drill another hole and put another bolt thru. Put washers on each bolt both sides.
Crude fix but better than welding to the header.
Put a "NO STEP' sign on the pipe. ;D
why not just put a proper exhaust clap on it?
$5-$10 at any muffler shop...
I'd put new mufflers on the 360. They aren't supported at the back, and if the only thing supporting it is the bolts, that seems problematic at best. The inner diameter of those bolt-on muffler tubes must be much larger than the headers if it is working itself loose.
High heat gasket maker works well when you are putting pipes together too.
