edelweiss said:I have a Yamaha DT360 (2-stroke) Enduro. How do I determine what the factory spec compression should be?
Here are the specs:
Engine Capacity: 351
Bore x Stroke: 80 х 70 mm
Compression Ratio: 6.4:1
Thanks!
John
barnett468 said:OK I'm guessing that you want to know what the psi should be using a gauge . . this info will be in the service manual but 6.4 static sounds like a typo to . . 8.4 sounds far more realistic to me . . either way, if the static compression is less than around 140 psi, something is wrong . .
