How do I get this off?
newbee101
How do I get the side cover off. It's the right side with the kick starter and points ignition. I removed all the screws around the case and removed the points plate. Behind the points plate is a star looking thing that is attached to the crank shaft. I believe that this has to do with the timing. The cover has separated but is there a special tool to remove this?
Underneath the rust, is there an allen head cut into the end of that shaft (as pj said)? Otherwise it looks like it should just slide right off.
