how do you take apart shocks!
JRK5892
Over 1,000 Posts
man, so for the life of me i can not get these F'n shocks apart! never done it, can not find anytihng on it... anyone haev any tips/tricks? i have a spring compressor... and here are the shocks (radian shocks and virago 250 shocks) i need to powder the shocks on them, but can not get em apart... here is what i got...
i just do not know how to do it or where to hook what.. i have done the springs many times, just always get them sent to me taken apart!
Don't know if your shocks are the same as mine but I couldn;t use the compressor as it would not close enough. The Virago shocks look like my hondas so this might work. On the underside of the top eyelit there was a nut, I put a wrench into the spring down were it would fit then swung it around in the spring until I got it to the top and onto the nut. That kept the shaft from turning and I put a socket extension into the eyelet and turned it until it came off. The spring poped a bit but nothing dangerous. Now, I cleaned them up and then had to put them back together. Of course no compressor, so I put the nut back on the shaft till it bottomed out, then to get the shaft above the spring so I could re thread the eyelet, I put a big flathead screwdriver on the nut and pryed the spring down/shaft up and started threading the eyelet on once started, put a wrench in and hold the nut, tighten down the eyelet until it contacts the nut. The other shock with the chrome cover???? Not sure. I would see if the clymers or haynes has the instructions. Good luck, and don't use visegrips on the shaft, I had 3 good shocks but one was stubborn and to get the top off I had to use visegrips and it is trash now. Thank god 2 came apart properly.
Just to cover off the question of how the compressor works - each of those hooks goes into a space in the spring. Turn the bolt and the hooks pull towards each other, compressing the spring from both ends. Then you remove the retaining ring above the spring and loosen off the compressor.
But that compressor is too big. They do make them for smaller motorcycle shocks. You might just take your shocks into a motorcycle shop and give them $5 to take the springs out, and then another $5 to put them together again. Will take them 2 minutes with the right tool.
Or you can buy the tool on eBay at least.
Maybe you can replace the hooks on the tool JRK they look like they are bolted in. Make them so that theycan come closer together so they will compress the spring. Just a thought.
