How hot is hot?
Tim
Administrator
Staff member
Embarrassing to say I don't know what a normal surface temp of a hot aircoolled engine should be.
Reason I ask is I need to do my ignition system wiring, and want to sleeve the wires. The braided sleeving has the following specs:
# -103°F to 257°F (-75°C to 125°C) temperature range
# melt temperature 446°F (230°C)
Think it will be ok resting against the cylinder head? Don't want a black plastic mess all over the place.
I've got one of those non-contact laser thermometers that I've played around with on my bike after running. It's been a while but if I remember correctly, the temp was around 200-230 F right around the spark plug (where I thought it would be hottest).
CC
Yeah, from the little I've found online (would've thought there would be more actual readings out there) 300 F is about the top end of things. Theoretically I should be ok based on the melting point of my sleeving being over 400. I know I can curl the ends with my heat gun, but maybe it gets even hotter.
Will sleeve it and see what happens!
if you are ever over 295 you have problems coming... anything under that is fine... the braided sleeve will take ALOT of heat man as long as it is not right against the motor you will be cool, 1 in off the motor will usually give you a 100* diff in temp!
Well this is coming right out the left side of the engine, at the end of the cam where the points used to be (Boyer ignition there now) so it does contact the cylinder head.
Gonna sleeve it up, make it pretty and hopefully it won't turn into a molten lump of black plastic.
