How to fix leaking peacock threads?
bmorunning
On my cb350k tank where the threads for the peacock meet the tank started to leak. How would I go about fixing this?
Thanks!
I put an o ring in there that I found that fit between on bottom and top threads, now if only my fuel shut off worked and the bowl on the bottom quit leaking, Fuck these stupid petcocks
I don't have a cb but I've had a leaky petcock I used locktite thread lock. It is gas and solvent resistant. On my xs750 tank the are two petcocks and I have used the thread lock on both successfully
Sent from my DROID RAZR
Lol peacock. Love that spell check.
It's not the petcock it self but the bung that's in the tank. Its leaking where it meets the tank itself.
There is an o ring that goes between the threads and the petcock. The threads press into the petcock and ring seafood this joint. Ten to one that is what's leaking. Replace that o-ring and you should be good.
So the actual tank is leaking? If so i would buy and install a Caswell liner. Otherwise you are talking welding. You sure it's leaking at the threads on the tank and not the joint between the petcock and the threads? Not that i doubt you, it's just an odd thing to start leaking, especially considering how good the condition of your tank is.
I removed the petcock and plugged the port with my finger and it still leaks. Knee dents where just put in and the tank got some fresh paint, it might of happened durning that. I guess I'll look into doing the liner. Thanks for the liner info.
Good ole fashion "JB"... maybe not that brand in particular but I used a similar compound from Permatex on a CB. It'll stand up to the fuel and set hard and smooth enough to paint.
I had a tank someone tried to repair with JB weld. Looks like it lasted about a day. Save yourself the future headache and line the tank, while you have it down, rebuild the petcock with all new rubber and you will be good for a while.
If the fitting is leaking at tank it is
Best to high temp silver solder or braze it, that is once you take all precautions to make sure you do not blow yourself up..dry ice chips , argon, etc..
If the petcock is leaking at the fitting all you need to seal it properly once fitting is surfaced flat and all parts cleaned is to use a
sealing oring and you should not need any sealant on the threads if done properly since the fitting threads are not tapered..
Joe@VCYCLE
Thanks everyone for the info. Just wanted to give you an update, I ended up using a epoxy resin from west. It's the 105 system, I use it at work for fiberglass and carbon projects. I drained the tank then flipped it over and cleaned the area around the bung. I filled the area with the 105 epoxy and let it dry for 24 hours. I reinstalled the tank and filled it up 1/8 of the way at first and let it set over night. Once I knew it wasn't leaking I fill the tank up and it's been good so far. I am pretty sure that the gas won't eat away at the epoxy, I mean they use this stuff to make carbon fiber gas tanks.
Emergency tank tip:
We took a long ride here in India, and for part of it we had the bikes on a train. Of course, despite our best efforts, they piled shit on top of the bikes a mile high in the cargo car; because of the weight, my friend's old rusty tank developed a leak along the bottom where a line of rust had worn the tank thin.
We were thinking we'd need to take a day or three to get it re-welded, but this big Sikh guy with us just asked who had a bar of soap and some jute fiber string. He ground the string up between two rocks, then mashed it all together with the soap and water. Once he had a big soft booger-like mass, he stuck it along the leaking bit, and it held all by itself. We then finished a loop all around Rajasthan without losing so much as a drop the entire way.
Thread title is cracking me up too--I actually scared a couple of monkeys into flushing a bunch of peacocks out of the brush this morning.
yeah, your best bet is to braze it. it really isn't that hard, and you can probably get good results with MAPP gas. i've seen so many variants on trying to patch a tank and most all of the have failed: the only difference is the length of time it took to fail.
just remember to buy flux. otherwise your braze will not stick worth a damn.
