"NEW" Cycle X charging system
* Single phase system allows battery or battery less operation. ( call for details )
* Rotor weighs only 1.640 lb's for high rev potential
* 14 amp system
* Kick only ( who needs a button anyway )
* Complete system weighs over 8 lbs less than a OEM system.
Note:
Honda's 3 phase field excited charging will create a magnetic pull when the regulator tells it.
This magnetic pull can reduce horsepower ( sometimes 2 horsepower )
Reduced rotating weight and less magnetic pull makes the Cycle X charging system the best choice.
Kit includes:
* 1.640 lb rotor
* 14 amp stator ( single phase ) and adaptor plate
* Crankshaft oil block-off sleeve ( Kick only )
* Crankshaft spacer.
* Starter hole block-off plug with fitting ( wires come out of this location)
* Solid state regulator-rectifier ( Made in USA )
* Gasket
* Instructions
$ 449.99 #CRG-1234
