How to use a Colortune, help please!
djg42
Hello,
I just got a colortune to help me rejet my bike. Testing the idle seems simple enough, but how about the mid and upper throttle? My idle was a good blue, but when i gave it throttle its all yellow. I had thought it was lean beacuase it was lacking power in the mid and high throttle.
What color should it be during mid throttle, full throttle etc...?????
Any advice on how to use it would be greatly appreciated, im new at this! Thanks,
DG
the same color as a good idle. if i remember a nice blue. not neon blue; thats too lean
Colortune????????is this like a tempel stick that welders use to determine heat????? several weeks ago,,the flyers hit the door step.....and there was heat gun on sale $28.00 cdn pesos with a laser pointer,,,I scouped that!!,,,,it is a great tool to shoot temperatures on exhaust pipes and track tyres,woodstoves,neighbours etc etc
Colortune is a device that lets you see the color of the combustion inside the chamber while the bike is running. I've never used one personally.
I've got a colortune - they're only good for idle mixture adjustment really. They tend to lose the plot when you rev a multi-circuit carb'd engine.
Best / most accurate / fastest way to get your jetting right is to take it to a competent dyno operator. You can't beat a rolling dyno with an AF analyzer for telling you what's REALLY happening in your motor.
Or if you want to do it yourself, get a bunch of pilot and main jets and spend the rest of the year experimenting.
