My cl 350 over the speeds of 70mph starts to wobble then clears up, not sure if it could be a bearing in the swing arm or the tires? It doesn't feel like the bike is going down but does seem alarming when it happens.
check that your triple trees are tightened down properly; that causes wobble. also check the rear swingarm and see if it has any play... might be easier to check with shocks/ wheel removed. besides those two; tire pressure can play a roll as well.
