Hydraulic Brake Light FIX??
stpilotdesmond
Active Member
Hey people! I have an issue I hope someone can help me with.
The front hydraulic brake switch on my 75 CB360 is broken. It's shorted out internally so I've been running without it connected. The original switch is no longer made so I had to order a universal one from Dime City Cycles.
Only problem is is that it's too long. See picture. The threads stop too soon and it doesn't go any further.
Does anyone have any suggestions to how I can resolve this issue? Maybe someone has an original working switch I could buy? Is there any other way of hooking up a front brake light switch?
Thanks for the help! Happy Holidays.
arent there switches that work with only pressure? kind of like a check valve.
i would hook up one of those, and get a stainless brake line while your at it.
Umm... I thought that the original switch does work with only pressure? When the lever is squeezed the master cylinder creates pressure in the brake fluid which closes the switch and completes the electrical circuit, allowing the brake light to illuminate. Does that sound right?
