I installed a (cheapo) tail light, need help making it work
grob23
Sketchy, But Effective!
I bought a cheap tail light from e-bay (China). The light has 3 wires coming from it: black, red, and brown. Any guesses as to what's what?
On my bike (1976 Honda CB200t), should the front brake lever actuate the brake light? Like is there a switch?
Lastly, my headlight is on all the time (with the key), so the tail light should be too, correct? It is not, is there a fuse I can check/replace?
I've done alotta research, and am almost at wits end. I'm probably just searching for the wrong terms, but I can't find a similar case anywere!
Any help would be greatly appreciated
Thanks a TON
-Greg
Greg,
This is an easy lesson. And time to improve your google Fu which seems to be very weak.
Tail lamp. Try black to ground on a spare battery and then touch the red and brown to the battery +ve terminal. One should be much brighter and that's the brake light connection.
Is there a front brake switch - check the manual first and then check the bike. If there is a switch on the brake perch, check wiring. If not it doesn't have a front brake switch.
There is no fuse between the headlamp and tail light. Check wiring diagram and then follow the harness to find the appropriate lead and test it for 12volts with a simple multimeter.
Wiring looks really complicated but if you treat it as a series on individual circuits you can test each one as needed.
Next, get a manual and wiring diagram to see which lead is ground on your bike and which go to the tail lamp and brake light.
Not sure what I'm looking for... my entire background is in bicycles, and while they're 100% legal on the roadways, they somehow aren't required to have brake lights. How will I know what I'm looking at?
If there is a switch you will find it somewhere on or around the front brake lever. If the lever perch is simple and plain with zero electrical connections, you probably do not have a front brake switch. I have also seen them use an inline switch. That is a switch built into the brake cable and again look to see if there are any electrical connections to the cable.
In the manual, check the wiring diagram and see if it mentions a front brake switch. Find the rear brake switch and follow the wiring in the diagram and see what it is connected to. if there is a front brake switch, the front and rear brake switches will be connected.
thanks again!
the manual shows a front brake switch, but I don't see anything on the bike, leaving me scratching my head...
I believe it's in the cable on these. Look for two wires coming out of the brake cable behind or under the headlight bucket. Not 100% positive on this, it's a but fuzzy, but Cb175s are like that and I think Cb200s are too. IT's also possible that if it's in the lever perch that the wires have been pulled out.
awesome advice, thanks for the reply!
I know the CB200 has internally rounted control wires. Through the bars
carnivorous chicken said:
The brake light switch isn't part of the internal handlebar wiring.
I'm pretty sure it's in the brake cable. Anybody got ideas on how to test it? Might there be a fuse for the front brake switch?
If it's in the cable, it is probably located close to the headlamp shell to hide it. Testing is easy. First disconnect the wires and test or continuity when you pull on the brake. If it is Open when not pulling on the lever and closed when you pull the brake lever, the switch itself is OK.
Next test for power to the switch. One of the wires you disconnected above, should have power when the ignition is ON. The other wire goes to the rear lamp assembly.
I think that bike has only one fuse - the main one. It's more likely that a wire is disconnected or has a poor connection.
I finally nutted up and opened up the headlight, as well as got the right hand control apart. First thing I'll say is that this bike is a MESS! (wiring-wise) It's like the previous owner(s) were color blind and didn't read their manual (the original manual has been kept with the bike).
I still can't locate the brake switch. I don't see anything of the sort inside the housing (which is where I would guess I'd find the switch), and the front cable is switch-free. Unless of course, this bike originally had a cable with a switch that was replaced for one that didn't, leaving the bike without a front stop switch.
Any ideas?
My guess is that you are right: The cable was replaced.
So if there is no switch, you don't need to worry about the wiring from a switch that isn't there - unless you want to fit one.
Yep, gonna replace the front brake cable and get the brake light working correctly.
It's not all bad, cause even if there was a switch in the housing it'd get changed. I hate the stock levers!
now all I gotta worry bout is the tail light 8)
