Before kicking the engine over, you should be able to turn the crank with a 14mm wrench on the end of the stator. Complete two full rotations (in neutral, of course) of the engine to check for clearance issues. Go slowly and if you feel anything binding, catching, or contacting; STOP.
If you put your full weight on the kicker and only got it to turn once, you've probably broken something already.
