i need help guys
hey guys, heres the deal have a cb450 and i can not get it to idle. iv totally rebuilt the carbs, adjusted the valves, replaced a bad coil, adjusted the timing, checked the compression and that was fine, just cant adjust get them adjust right. could it be because there isnt a air box on it? thanks
ryan
ryan
Prolly not the airbox. My cafe doesn't have one and its running fine
Lack of an air box shouldn't affect it. When you say it doesn't idle, what exactly do you mean? Is this only when the bike is warmed up? Does it idle fine when warming up on the choke? Have you synced the carbs (although it would be hard to do if it doesn't idle :))
When you rebuilt the carbs, did you ensure to clean out the pilot circuit? Also, air leaks could affect the idle, so check to ensure there are no leaks between the carbs and the engine.
thanks for replying so quick guys yeah the bike wont idle at all. start it up let out of the throttle and just putters out. no matter what adjustments we make. if it does idle its only doing it on one cylinder. iv been thou the carbs twice now and all the passages are clear and everything is as it should be. any ideas?
Are you getting spark to all cylinders? You mention they are not all running so that may be one cause. Also, check the timing. When I checked mine, the 2-3 cylinders were dead on but the 1-4 were way off. It would idle but not real steady. Fixed that and it is rock solid now. Worth a look.
Also, you probably already tried but maybe just adjusting the idle screw.
Check the floats levels as well, if they are off they can affect a host of things.
yeah i got it over at my freinds shop who works on bikes for a living, i dont think e has much if any experence with that type of carb. but he and i when thou the timeing, checking for spark and that was working fine. i gotta get over there monday and double check everything there has to be something small we are missing.
Best of luck with it. If you do fix it be sure to post back, I'd be interested in what it is. Like you said, it's probably something small.
Have a look at the pilot mixture screws when your at it as well, they may need to be adjusted. Maybe set too lean which would make the bike stall when idling.
