I need some more CB550 carb help!!
Modgod1
1974 Honda CB550 Cafe Racer in Progress
Ok, my carbs are super clean after boiling them in lemon juice (acid), but I left them in too long, and a powder residue was left on the carb bodies, but I figured that out, just scrub with soft steel wool. So, one carb body done, 3 to go, but on the 2nd, and this is the problem.
A small ballbearing fell out, I don't know from where, then came a small spring (not the spring on the adjuster screw, but that type of spring about half the size. Please where do these go?
Thanks.
Part of the enrichener actuation mechanism. The rod that actuates the enrichener has a little indent in it. That ball bearing engages in that intent to hold the enrichener rod in position.
Thanks for the reply AlphaDog, yeah I was able to figure it out once I started putting it back together, it's only on the #1 carb, the back part of the choke lever (enrichener actuation mechanism), thanks again.
