rockcitycafe
I make things.
Ok, so i took the 400f out for a ride today, enjoying the fact that i had just done a full tune up, valve tappets, camchain, chain, oil change, carb clean and synch, etc etc, she ran really really well right after the tuneup, but it rained the day of, so today was the first good day to take it out. so i was tooling around, out on the highway etc, ran really well, then came off and stopped at a light and the idle was high, so i turned out the throttle screw and brought it down again, went off tooling again, then next time i hit a light, the idle was high again, turned the screw out, and etc etc... finally after doing this about 5 times i figured something was goofy, i looked at the throttle screw and it was completely out, the engine was still clocking 4k with the throttle bodies presumably completely closed... damnit. I figured something had gooped up the idle jets and was causing this thing to run lean and very hot, so i limped it back to the shop and took the carbs off. i went straight for the idle jets after getting the gas out and the bowls off, took them out and inspected them, and to my surprise, they were clean, emulsion tubes too... so here i was beating my head against the wall when i turned the carbs over... and it hit me, each one of the locknuts on the carb bodies that lock the height adjustment after syncing were completely loose. when i looked down the throats two of the throttle pistons were about 1/8" off the deck and the other two were sealed tight as a dolphins ass. there you have it... a complete anal retentive tuneup down to the last bolt... but not the last 4 nuts...
hahah
hahah
