Identify Electrical Parts T500 Done!
johnu
Over 1,000 Posts
DTT BOTM WINNER
I am lame when it comes to the electrical stuff so I have a couple questions about the wiring on my t500.
I will be wiring to a bare minimum just enough for turn signals, brake lights, head light (no hi/lo beam), rear light and horn. All lights will be led's except for the headlight.
1. What are the parts in the pics below, I think the single part is the rectifier and the other two maybe voltage regulator and flasher relay?
2. Is it better to use heavier wire to be on the safe side? I plan to use 16g for most of the wiring.
3. I plan to install the parts in the pics and the battery in the tail unit, do any of them need to be in an unconfined space for cooling?
I am just trying to get all the electrical parts together and start positioning components. I'll likely have a ton of other questions as I go on.
Re: Identify Electrical Parts - T500
Those are the magic smoke reservoirs - they turn on when wires touch metal, releasing their pungent... I mean fragrant... FRAGRANT... mist. Smells like... victory.
Re: wire gauge - use the same thickness as the stuff you're replacing - they chose that gauge for a reason. If you REALLY want to help yourself out later on (or whoever owns the bike after you), be sure to USE THE SAME COLOR AS THE STUFF YOU REPLACE - aways - and never just use som generic red or black wire. There's nothing worse than having to try and repair a circuit that you have no idea where the power's coming from because some nimrod replaced all the wires with some crappy, generic, same-colored crap, making the wiring diagram impossible to read any more. Seriously - don't be that guy. Harbor Freight has entire sets of every colored wire imaginable all in a bundle kit for, like, $5.99 (I'm only exaggerating a little), so just go buy the multi-pack in the rigt gauge and then use the right color for the job... :)
That's what they look like to me as well. You can verify this by locating the item on the wiring diagram in your manual and matching up the wire colors.
Using heavier gauge wire than what you're replacing is generally not a problem, just DO NOT ever use a lighter gauge than what you're replacing. That's how things melt and/or catch fire ;)
The regulator and rectifier should have some airflow over them for cooling. They don't have to be out in the open but don't box them in either. They're usually bundled behind a sidepanel, so figure about that much exposure and go from there.
Thanks, I hadn't thought about matching the wire colors to parts in the manual!
I'd start by throwing those parts away and wiring from scratch with new components and new wires and connectors. I cannot imagine trying to get a custom bike to work with old OEM electrical components. Tony at Oregon Motorcycle Electrics will sell you a new modern Regulator/rectifier. Fuse boxes are available from many places. I prefer Eastern beaver, but others are available. Flasher relay from your local auto parts store headlight relays from the same place or Eastern Beaver. It's cjheaper that way in teh long run and a whole lot less frustrating.
First pic is rectifier and regulator, second, not sure what that is not flasher relay though (I should know but just don't recognise it)
You will be far better off getting a solid state reg/rect and wiring from there
I'd absolutely like to do it that way for sure, problem is I would be totally lost (I am lame at the electrical part) when trying to select and order the right parts. I guess I could call and try to explain what I need. Also have to consider the budget!
I do intend to use all new bullet connectors and those two pin plugs that I saw on the link you posted at the top of this page.
I am going to buy all the lights, switches and horn that I will use then lay it all out and go from there. I plan to use one of those small Ballistic batteries for this project.
Ok, tried this today but the wiring diagram I have is for a T500 (points ignition) and my bike is a T500 but with a GT500 engine which has electronic ignition. None of the wire colors from the parts in the pics matched the wiring diagram! The part in the bottom pic has a three pin plug which connects to the ignition so I assume this is part of the cdi?
Re: Identify Electrical Parts T500 - Done!
All parts now identified and time to begin figuring out what I can eliminate fron the mess in the pic below! Also planing to use the same powersource battery (ballistic is too expensive) as shown in the pic below with some of the other parts I have been gathering. This battery is a 4ah I will be using a 6ah which is the same physical size. Can these sealed batteries be laid on there side?
The part in the bottom pic is the cdi unit.
