Identify These Wires (starter/three-way)
PHeller
Coast to Coast
I've got a non-stock Starter and Three-way on/off switch on my bike and I'm not sure what wires are what.
I'm pretty sure its a Honda unit, maybe off a Goldwing?
Anyone know what these wires are for?
u can do a continuity test on it or just open up that switch and check out what colors go where...
I dug around a bit and found that the starter is likely for a 80's GL1100 or GL1500.
The yellow/green and white/green are likely for a brake switch that my CB400 doesn't have.
yellow/red is your solenoid switch, you've got the front brake wires sorted, black, black/white is engine stop switch, blue/white is headlight power, black/red is power for everything from the fuse.
hope this helps
cheers
ian
