Idiot light LED replacement panel question
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
hey elctrical geeks :)
i have a question on replacing the existing Idiot lights of my gauges on my Yamaha RD 250.
its a 12v system with 5,5 Ah battery.
i would love to make a panel like seen in the picture (hope i am allowed to steal this great idea from Squadra :-)?..)
if i replace my existing little bulbs with coloured led´s do i need to have any resistor or is it really a plug and play thing.
i know when it comes to flashing blinkers leds need restistors in order to function cuz of their lower resistence.
hook up plus and minus...and finished...??
im sorry im a noob coming to electrics...
thanks in advance
Some LEDs have resistors packaged with them and some don't. Grab the one you want to use and try it with and without a resistor.
I used 2 LED's on my T500. One for neutral, and the other for main beam. Simply connected them into the wiring and they work great. They are very bright though. Check out ebay...there are some M8 LED's which bolt straight into your new dash.
thanks titan!
who is it with the blinker idiot light?won´t the new led blink like hell if i replace the existing bulb?
the other idiot lights are not blinking ones...so this one is my biggest issue.
If the only bulbs you're converting to LED is the dash lights, you should be ok. The Edison bulb turnsignals should draw enough current to trigger the OEM analog flasher relay without the "rapid flash".
thanks redbird!i m thinking about switching my blinkers too to led ones...so i will need a new flashing relais and resistors dont i?
Yes, if you convert the blinkers to LED's, you'll need to switch to a digital relay. They're readily available from several sources ;)
Forget about resistors though. They're not needed with a digital relay.
This is very true. Cheaper and easier to get the digital flasher. If you go the resistor route you lose the savings in electrical draw you would gain by switching to LED's. There is only one thing to consider in the whole thing. Do you have 2 signal indicator lights, Left and Right, or a single one for both. Sonrier has a diagram to make the LED work when it is a single indicator as the current changes and it will only work in one direction. To make it simple I would just wire in 2 LED orange signal leds and put them in your new dash. That is what I did on my CX build and with the digital flasher, all worked well.
Oh yes and there is a good ebay seller that lets you buy a pack of 5, 6, 7, 10 etc and mix the colours to what you want. I got 4 clears for guages, 2 orange signals, 1 red oil ,1 blue High beam,1 green for neutral and it was less then 20 bucks shipped. If I still have history in my E-Bay I will post a link.
my RD has 2 signal indicators lights.
so with this setup you would do separate flasher lights for left and right...?
thank you!!!
Yep, easy to do, just hook the new lights up to the same wires the old buls use and you should be fine. I can't find the ones I bought, well because my FIL actually bough them as they were for his CX I built. I tried a search quick but didn't see them, I'll try again when I get a chance.
fine!
another question.are these leds waterproof?
