C ceggertcrowe New Member May 25, 2016 #1 Has anybody flushmounted LED idiot lights in the handlebars? Something like this (terribly crude) sketch? If you have, what problems did you run into and where did your source your LEDs? Thanks! Attachments sketch1464185793836.png 200.1 KB · Views: 682
vandito.cb Been Around the Block May 25, 2016 #2 there should be no issues as long as they're wired properly and given enough slack to move around with the handlebars. Sonreir sells small LED 4 packs for less than $10. http://www.sparckmoto.com/Products a small bracket may be better suited to seat them in. I can't see making four holes in the middle of a handlebar being healthy.
2_DONE_THE_TON Over 1,000 Posts DTT BOTM WINNER May 25, 2016 #3 I would not recommend drilling your bars for setting idiot lights.where would the wire go out of the bar?
VonYinzer Over 10,000 Posts May 25, 2016 #4 General rule of thumb... Don't drill holes in handlebars unless absolutely necessary.
