idiot-lights in custom dash,
Mr.B
Everybody likes curves, when we talk about roads.
Okey, the dash isn't 100% complete yet, but have been struggling the last 2 hours with the soldering of 1.2x3mm sized LED's onto a custom PCB-board.
Since I'm no pro and using a solder that is far from ideal I'm not going to show my soldering work, but I figured I show you all that it works!
The PCB, simple as simple can be!
Fitted with these (M6x40 for scale, they are TINY!)
And a couple of shots with the pcb, soldered, fitted and running on a 9V battery (so not as bright then when it's gonna be hooked to the 12v)
Each light consists of 3 leds in series with one resistor.
Then wired to the original loom so all original connections can and will be used.
Next to do is get some frosted plexi in the slots over the LEDs to get a smoother light transference and add some isolation around the pcb-board.
Great work! Those tiny led lights give me a headache just thinking about soldering them!
Thanks boys! :)
Yeah, they were a small pain, but with a tweezer they were not unmanageable .
The hard part was to use the soldering iron with a tip that was larger then the LEDs themselfs :D
