Idiot Lights
frenchy
Active Member
Has anyone built their own idiot light panels? I'm thinking really small and concealed, to get rid of the huge panel on my cb750. Maybe LED? Carpy has some for sale, but not exactly inexpensive.
Any ideas?
A lot of people on here build their own housings. Look for Bobdot's scoot - he has a great plexi one. If you run clipons, you can use the original riser mounts as well
go to radio shack bud they have a ton of small light that are tinted and pre wired wiht resisters. i use them all the time!
I made mine.
here are some i have done with radio shack lights
customer only wanted a "N" light
cafe (light on the top)
my harley (all lights)
Thanks Joe and DrJ. Those look great.
I'll have to check out The Source here in Toronto. If I use LED is it necessary to use resistors? I figured resistors were only needed for LED turn signals because they flash on and off.
What sort of lights are you using, LED or 12V bulbs? How are they held in the panel? Are the lights themselves threaded so that you can thread directly into the panel or backed by a nut?
Anybody else?
Why do you want the lights at all by the way? I got rid of mine on my XS650. I don't need a light to tell me I'm in neutral (hard as hell to find on the XS and when you get it you know it), my turn signals are visible to me as-is and even then I forget to turn them off, no oil pressure/temp lights to bother with, and a high beam indicator? wtf use is that?
I say save yourself time trouble and money and just ditch them.
Tim they are nice to have bud, if a friend ever rides the bike it is nice to look down and see your in "N" or check your oil pressure, those are typically the only 2 i run on chops and cafes. the turn sig indicators on occasion just so i am not that idiot rocking flashing lights all the way down the road! ha ha ha
from what i can tell they are LED i know mine are they are threaded and have a small nut and lock washer on them 12v
Thanks Tim, the thought crossed my mind, but i have to agree with Joe, especially N. Turns I can see & so not needed, same with high beam. Was thinking of picking up a speedo with the lights incorporated, but I like the stock speedo. Just thinking of N & oil.
Thanks Joe, those sound perfect. What's the price on them?
It's a legal requirement to have a high beam indicator light in most countries.
Just sayin'.....
Hmmmm, thanks hillsy, i'll have to look into this here in Ontario.
Does anybody else have good pictures of their idiot lights? I've looked through a bunch of threads...looking good.
Totally agree Tim. I just made a panel for my KZ and actually bought LED's and holders for the idiot lights. Went through all the trouble of drawing it up in Photoshop. Then I thought...WHY??? I'd never look at them, just a waste of time and effort. Ended up just putting the ignition switch in it. Still have the space for the lights there, but I'll probably trim it down a bit when I get a chance. Or put a clock/watch there.
Pocket watch style clock would be tits. I would however keep the oil light someplace for peice of mind, but the rest, who cares. I have had one motor saved because of the oil light. Only reason I would keep one. That red light flicking on will catch your eye and tell you if something may be amiss with the heart of the beast.
Nice gauge bracket. I hope to do something similar on my little honda when I get her back.
Cheers.
Maritime
robb. said:
Nice bracket Deacon. Did you take the drawing to somebody to have it cut, or is it your own fab?
Thanks, that bracket was honestly a 5-10 minute quick job just to have something to mount the ignition switch. I planned on doing a better job but, like everything, never get around to it. I just printed off the picture I created, cut out the basic shape, traced it to the metal and quickly used a angle grinder with a flap disc to shape it out. That one is made out of a stainless steel coaster I had laying around. I'll probably do another over the winter.
