Red Fthr
"Man is born free, and he is everywhere in chains"
Bike:
1973 Honda CB500 Four K2 (everything stock except for exhaust and dyna ignition)
Problem:
The bike will idle to 4k (sometimes higher) after it's warmed up and once the throttle is given more than a lil blip and after an additional blip it'll fall to a dead idle and shut off. You can however hold the throttle at the proper idle and once you hear the bike is stable you can let go and it'll stay there but as soon as you give it more than a blip it jumps back up.
Theory:
The bike hadn't been running for several months when I received it. After a carb overhaul/ rebuild (with larger jets; 38) it kicked over with no choke on the second kick. Nothing is sticky and everything is nice and springy. I then benched synced the carbs and hooked them up to a vacuum sync-o-meter (I got pretty close with the syncing) but I haven't gone completely trough the syncing process because of the idle issue. All my plugs indicate the bike is running rich, which could be because of larger jets because the float heights meet manual specifications. I also tested for air leaks and after spraying I got no high revs. I feel it's totally mechanical and not mixture related but I could be wrong.
Questions:
1. I have my adjustment screws loose during this whole process (for syncing purposes), could that be the cause?
2. Could timing be the issue? How do you adjust the timing for dyna ignition?
3. Would a rich mixture cause such terrible idle issues?
4. Could cable adjustment or throttle stop adjustment be the cause? I've never messed with that stuff before so I'm pretty ignorant to it's capabilities. I did disassemble mostly everything so maybe something isn't functioning right there? All though the slides are dropping/ springing back after releasing the throttle just fine.
I've tested out a few different theories and it's now almost 4am here in FL. and I've exhausted my current knowledge on the subject of carbs (which isn't a whole lot I'll admit). This is when you awesome people come in handy and I would appreciate any wisdom you can throw my way.
Problem:
Theory:
Questions:
