johnson_steve
Ok my cb400t has always idled like crap and needed lots of choke but now I kick it and it screams! I've never been able to get the idle speed set properly but usualy this meant the occasional stall and having to keep my hand on the throttle. now it idles obnoxiusly high all the time. I backed the idle speed screw out all the way it doesn't even touch. I checked the plugs it was running rich so I set the idle mixture screws to 1 1/4 turns out from tight (I had adjusted them more rich in an attempt to make it run without the choke on all the time.) the slides aren't stuck. I'm pulling my hair out here. if there is load on the engine it runs just fine but as soon as I put the clutch in or put her in neutral she revs really high. I wish it would just go back to stalling
