idle weirdness
johnny gaijin
if my idle hangs at 4K but drops down where it's supposed to be if i let off the clutch until the bike starts to creep forward and then pull it in again; what is that indicative of?
Re: idle hanging
Air leak around the intake? Try spraying some WD-40 around the carb flanges and see if the idle changes.
didn't find a vacuum leak. but did notice that after some adjustment i could get it to idle great in neutral but as soon as i disengage the clutch and put it in gear the idle drops eventually dies. putting it back in neutral causes the idle to raise to a proper level. at first i thought maybe the clutch lever wasn't completely disengaging the clutch but i adjusted it and still no change.
what gives?
crazypj said:
The clutch IS dragging and needs proper adjustment
i can tighten the clutch cable so tight that the bike doesn't immediately stall if i put it in gear w/o pulling the in the clutch lever but the idle still drops and will eventually die... am i missing something?
thanks for the help so far!
Adjusting the cable is not adjusting the clutch.
The release mechanism has to be correctly adjusted before the cable.
Have you got correct oil (10w/40) and correct amount?
Clutch drag is common when 20w/50 is used or the level is too high
PJ
would too much oil cause this problem? because the gearbox was way over full. i drained it to where it's supposed to be and it seems to be working better but the idle has been so obnoxious i'm not 100% convinced that i fixed it...
