Ignition Coil ~
Luugo86
'73 CB350, '78 XS650 Cafe Killer
Does anyone know a reputable place I can order a good aftermarket dual tower ignition coil with a resistance between 3-5 ohms, that will work with a 1975 CB200..
Im doing a swap for a bore-tech electronic ignition system and want to also upgrade to the aftermarket dual tower coil, just havin some trouble finding one. Thanks fellas, Cheers!
,Dave
i use these on my high performance engines a bit pricey but awesome output and quality
http://www.nology.com/profiremotor.html
Mice coils, but only 3 ohm and 0.6 ohm.
For a point ignition, they are going to draw more current, and be harder on the points. The site does not recommend them for point ignition either. O.K. for CDi or electronic.
A 3 0hm draw 40% more current. With our minimal charging systems, the extra can put you over the edge.
