IGNITION COILS 1975 CB360
Stock will be the easiest to mount up, but coils are mostly the same. I know a lot of folks swear by the coils on mikesxs, but they do require some light modification to fit them onto a 360.
You can always go with a universal set of coils from DCC and get a electronic ignition from Pamco. The mounting is pretty easy you just need a simple piece of flat stock to mount them. Plus their only $24 a piece!
http://www.cb450ignition.com/Index350.htm
Specify you're ordering for the 360 if you decide to buy one. The points plate is a different size than on the 350 but the kits are essentially the same.
