cafechris
I was putting a new battery back into a 81 Honda CB750C and managed to touch the screwdriver against the left ignition control module and had a slight spark. I tried to start the bike after it has been sitting for two months (welding the shock mount back/bracket after the bolt broke off during a wreck and doing physical therapy on my shoulder caused it to sit) and now it will not start. I pulled the spark plugs and turned it over just to keep oil in the cylinder, but can't get it to fire off-even with spraying some ether in there. I pulled the plugs and there seems to be a slight spark when I set the plug(s) against the case and turn it over. Could I have fried the ignition control module? If so, can I replace the one or do I need the set? If this is not it, I will pull the carbs and sonicate them as varnish may have resulted from the gas (using ethanol free) sitting in the bowls. Perhaps the needle valve or floats are not seating properly and it is flooding out?!
THANKS in advance for any help!
