Ignition Grounding question
gomotomoto
Can I ground the ignition to the bolts (going through frame) the hold the coil bracket on?
you are probably fine, unless you powdered the frame so well that the coil bracket isn't actually in contact with the metal of the frame.
A quick continuity check with a multimeter between that bracket and the negative lead to your battery will tell you quickly if that is a good ground point.
Sometimes getting things all clean and shiny and pretty makes for electrical issues...
lingo said:
If you are truly worried about it run a ground wire to the battery
There's always 2 ground wires. The battery ground and the wiring harness ground.
Originally there was a bare metal section under horn mounting bracket where ground lead lived.
Remove some paint/powder coat under one of the coil mounting brackets.
A star washer works pretty good to cut through painted sections but fit one under both bolts so bracket doesn't get cracked
