ignition switch
vandito.cb
I'm still very new to electrics and i recently purchased an automotive turn to start ignition switch. it's a 6 wire (although only 3 are relevant) switch so i'm curious as to combining the harnesses from the original ignition switch as well as the r/h starter switch.
i know one wire is hot, one runs to the solenoid and the other feeds power to...everything, but i'm now left with a need to clean up the wiring a lack of a push button has left behind. ideally, I'd like every unnecessary wire gone without having to unloom the entire wiring harness just yet.
thoughts?
Sounds like you have a decent understanding of what to do.
Not what the question is, though?
i do to a degree. if i were rewiring one or the other, i'd be fine, but combining the two seems a tad trickier.
i also haven't actually had time to truly sit down and look at it so i'm sure there's something mind bogglingly clear that i havent seen.
i suppose my question is...theoretically if i ran the starter solenoid wire straight to the...starter solenoid and the hot wire straight to the battery, whats the easiest way to feed all the electronics that get power under ACC/On positions?
Find all your power wires from the old ignition switch, splice them together, and connect them to the remaining post on the new ignition switch.
I meant it as in i still want to use latching connectors and I'm not sure how many wires there are for each of everything so say I had one power wire that needs to feed 3 more, what would be the best approach.
i'm assuming every bit of wiring from the R/H switch can be pulled off and done away with, correct? because with this, I'm left with the stock 4 that come from the ignition switch itself.
I'm afraid I don't understand your first sentence. You can use whatever connectors you'd like.
For the right hand control, you can remove whatever wires you aren't using. Be sure to cap off the live ones, though, so you don't cause a short circuit.
I'm not sure how to explain what I'm asking. I'll get to it this week and figure it out, I suppose.
i appreciate the input, BTW.
