Ignition timing. Spark advancer 180
MB
Coast to Coast
Cb350.
Piston TDC- valves loose. Light stays on. Turn the rotor 180 and the light goes off and turns back on at LF. Valves tight. Did I put my spark advancer on incorrectly?!!!!!
Possible, though the valves shouldn't really be loose until about 90° ATDC when the right cylinder is in compression stroke and the left is in power stroke.
So i will try to without the language necessary. The variables are starting to add up. No matter where I set the gap the light turns on at LF 180 out. I assume it's not TDC because the left side valves are tight at this point. The light stays on past another 180 and again, synchronizes with the LF 180 out. What approach should I take from here?
