One of the last things that I need to do in order to finish up my bike is to make a seat cover. I've made the seat pan out of 16ga. steel. Foamed is with a couple of different materials and ordered vinyl and started trying to make the cover. One disclaimer is that I've only sewn a couple of things in my life and I'm using a home sewing machine with a walking foot that came from my grandmother. I purchased the vinyl and thread at sailrite.
My general plan for the cover is something along these lines.
I found these pictures online.
I think I'm going to go with more of the top image that does not have the border all the way around the pleated parts.
This is what I have so far.
This is not sewn together but I did try this and I could not get the material to lay properly.
I need advise on how to cut the rear section so it will lay smoothly. Should I be using just a straight cut piece of vinyl and follow the curve downward on the side of the seat or should I use a curved boxing as seen in the picture above or should I actually cut a piece of vinyl that follows the contour of the rear part of the seat similar to how the pattern below was done. And I may need to make it in two pieces. I just need some advice from someone who has done this before. Thanks in advance.
Here is the bike that it will eventually go on in the mock up stages.
