Indicator blinker on DCC mini gauge.
Sonreir said:
Except if you decide to use diodes, use a lineman join. The method used in the pics above will likely fail due to vibrations in the bike.
Do it this way:
Your picture has the diodes in series Sonreir? or was that just a simple illustration of the twist tie technique to wire correctly the first time?
Just an illustration of the wiring technique.
The diodes should be wired as shown in the original pic from SOHC4 Pay special attention that the anode side (side without the gray stripe) of the diodes do not touch one another after the wiring process is complete, it will defeat the purpose.
Sorry, not the best wiring/soldering in the pic I posted from the other forums, just wanted to show the layout. I didn't snap any pictures while doing my own.
As if I didn't feel inadequate enough from the first pictures, Sonreir comes in with the artsy twisting techniques... ;D
Its a pretty sweet speedo in my humble opinion. Once you deal with the blinker issue its awesome. The lights are very bright too. I'm pleased and I haven't even used it at night yet...
Yea, besides putting in diodes it just wires right up to where your stock gauges and indicator lights were. You just have to know what wire is what, so a wiring diagram helps. My only complaint with the indicator so far is that the high beam indicator LED light is super bright. Riding home from work at night, I flipped my high beam on when I got to a poorly lit street and it caught me off guard. It's damn near blinding.
So true. High beam indicator is ridiculously bright. Although I haven't been blinded quite yet...
No tach?? ballzy
