Jewbacca said:Also, remember when you tighten bearings, don't crank down on them. You tighten it down to make sure they're seated, then back off until you can turn it by hand. Hand tighten and then add 1/4 turn with a wrench. Any adjustment after that is simply to take up any slack in the head stock. Tighten them too much and they'll wear down in a hurry and create jerky steering.
thats about it for the balls type1sttimer said:Is there a torque rating on this? I reinstalled my ball bearings and not tapered rollers and I'm wondering what Honda did at the factory to make sure that top spanner was right enough. I've noticed the grinding feeling when you over tighten, but if it's just hand tight won't it vibrate loose?
What danger am I in if that spanner isn't torqued down properly?
What I did was hand tighten and twist the bars. I kept tightening until I felt the balls start to bind and then backed off. Is this the right way to do it?
teazer said:Yes they are called races for tapered roller bearings, and the normal terminology that carried over from the pushie/treadlie/bicycle world is cup and cones for ball bearings.
teazer said:Stem nut to 66 foot pounds!! That seems just a tad on the high side.
Just to get this clear, the tun under the top triple clamp is the one that adjusts the end play and clamping pressure. Get that right and then tighten the top nut (above the top triple clamp) to bring the top triple down snuggly on top of the adjusting ring nut.
sharperdill said:I give up. No one can read and follow instructions before they post.
xb33bsa said:this effect varies depending how loose the thread fit is in the adjusting nut.....
tightening the top nut can take up the slack in the threads out of the adjusting nut causing more preload on the bearings if so you will need to back off the adjusting nut a smidge
a little trial and error will get it right![]()
