Intro and question
daikonashi
Hi all, my name is Scott and I am new to the forum. I am trying to help a neighbor get a 1975 cb125 up and going. The problems I am seeing are: weak headlight and horn, blinkers aren't working, and I am doubtful that it is charging. I am trying to eliminate easy stuff first. I have cleaned the contacts on the left switch, got a new battery and done some general cleaning. Bike runs, just trying to work out the electrical.
Any ideas on what I should focus on next? I suspect the stator, but have heard that these 6 volt systems can have a lot of quirks. Are there common grounds that get gunkified?
Any help is much appreciated!
First step is to measure the voltage across the battery terminals. Ensure that voltage rises to the low 7V range (anything between 7V and 7.5V is OK) when you rev the engine up to about 3000 RPM.
