inverted forks
funkja
Active Member
anyone have a walk-through or tips on replacing a set of forks with updated inverted ones? gonna start the '73 GT185 this fall, 30mm front forks.
Yeah I gotta agree with PJ, it reeks big time of overkill, still its your bike but think about balance and symmetry whenever your building a bike ;)
cheers, GK.
I wouldn't do it on a little bike. The USD forks are heavier than conventional. But if you must, check this site out. http://vintagefighters.yuku.com/
Sorry man, unless you're talking about Z50 forks vs. R1 USD you're just plain wrong.
If they were heavier every manufacturer fielding a race team would be running regular forks or something else instead.
To the Original Poster:
As for fitting them, depending on the length...look into a pair of higher end pitbike USDs. I picked up a pair with billet triples for one of my S90s. They ran me 345 for the set, weigh a few pounds less than even the spindly S90 forks and are so much better it's not even comical. Mine are 28" long overall, made by Marzocchi (sp?) and will handle anything this (or any) little bike is going to hand them. You can even get 'lesser' quality pieces from ebay that'll do what you want, be lighter and better than anything OEM for your bike.
You'll also need desperately to upgrade the rear end of your bike to play nice with your new spiffy front end. Also, you....depending on your brakes, you may want to look into bracing your frame....
Good read, well worth perusing as long as you can stomach the fucking retard bikerspeak writing style.
Personally I prefer to swap the stem whenever possible rather than kludge together something with 'extensions' as it WILL increase the load and especially the off-axis load on the stem since those cups WILL flex unless they're welded in (hoping for similar enough material to allow welding).
Probably would be great for a hardtail like the one shown, that will more than likely never be pushed hard enough to worry. Yes, I'm sure someone will be stupid enough to flog one hard (saw that coming....) but, well......if you're flogging a hardtail enough to be an issue you deserve what you get.
