is it worth it 1977 cb550f
herbiehonda
shes a work in progressive
I purchased what is pretty much a barn find for a few bones last week. The engine is free but has not started yet. When I did try and start it last night the clutch cable snapped. Everything seems to be a little gummed up and I feel it will need to be completely stripped and rebuilt. My question is should I dig into the project or part it out and part ways. Its the same bike that I have in my profile picture.
I'm not sure what you're getting at -- the clutch cable snapped so you're not sure if it's worth trying to get this thing roadworthy? You can, of course, get the engine running (if it's gonna run) without the clutch cable. Try that first.
And before you tried to start it, you should've checked for spark, cleaned (at least) the carbs (if it runs you can rebuild them), put a couple drops of oil in each cylinder, cleaned the plugs (if not replaced them), cleaned the points, checked the air filter, charged (or replaced the battery), etc. Trying to start a bike that's been sitting without cleaning out the carbs is a recipe for getting shit more gummed up.
I've worked on many bikes that have sat for years, done those steps, and gotten a fine bike out of it, without having to open up the engine or work on the clutch. Luck of the draw. But you won't know until you figure out if it's gonna run first.
Forgive me for not explaining myself completely and thank you for your response. I am new to the forum and new to motorcycle mechanics, although not new to engine work. I have rebuilt a couple cars over the last 10 years. Let me start with what I have done.
Pulled and cleaned the carbs, (the main jets were completely clogged), I pulled and replaced the plugs, and I cleaned the tank out. (Lots of shaking) last night when I tried to start it with the kick the clutch cable snapped and it seems as if I lost compression.
I am confident I can do what ever work it takes to get the bike running but I lack experience with motorcycles.
The bike was purchased for $200 without a title (I should be able to get one through VT though) so I guess I am trying to figure out if I should part with it and start with something that runs. already
Well, it's not so much the getting it running - 90% of that is likely just cleaning the carbs, new plugs, setting the timing etc.
The CB550F is a great bike. Good engine, good tranny. The engine can be torn down and rebuilt without pulling it from the frame (I've done it twice). The big thing about the one you have is the wheels are incorrect. The CB550 came with spoked rims. You should be able to get those pretty cheap though, and just bolt them on. Of course if you like the Comstar mags, then you're ahead of the game.
What style of bike do you want? The CB550 will make a great cafe racer. Those sidecovers are also worth a bit of money if they're in good shape. They were specific to the CB550F and the right side often cracked (it covers the battery).
Keep tinkering. Do a compression test to see how good/bad each cylinder is.
Ultimately I want to build what I would consider a gentleman's Cafe. Something like this.
carnivorous chicken, I do not have a manuel as of yet but I found one on here, just need to print it off. Here are some additional pictures of the bike.
*Manual
Can someone tell me what this is hanging down beneath the instrument cluster?
P.S. sorry in advance for any and all newbie questions and thank you in advance for any and all advice/help
Redliner said:
Looks like a flasher warning.
Exactly what it is, pull that thing unless you like a beeping noise every time you signal a turn. And yeah, those aren't stock wheels (I'm partially to spokes myself), nor is it a stock master cylinder, nor exhaust, nor rear blinkers... and of course not the stock airbox (and those pods look knackered). Seat's been trimmed too.
You shouldn't be trying to kick start it with the clutch lever pulled -- the kickstarter won't engage. No need to worry about pulling the cable now that it's broken; just leave it in neutral to kick it over.\
Tim's right, it's not just about getting it running. But that's the first step to know if you have a bike that's going to be worth holding on to. A few other things to do:
Make sure it has spark. IF it doesn't find out why -- check your electrical continuity.
Check the points.
Check the timing.
Make sure your fuel isn't clogging the jets again.
Run an inline fuel filter for now, and recoat the tank if it's a runner.
You're gonna wanna replace those pods, but for just trying to start it take 'em off, shake 'em off, and make sure they don't have a bunch of shit in 'em.
Shitty old tires will work for now, but if it's a runner you'll need new ones.
If the thing fires up you're going to wanna make sure you can run through the gears. As long as nothing is fucked up or bent or rusted through on the frame, it becomes a question of what to fix first and how long until you're riding it.
Do exactly what you are asking if you should do- part ways. Find a decent clean, running bike and modify it the way you want. Be patient, watch Craigslist and for around $1000-1500 you will find a bike. Don't be afraid to walk away from bikes, hold out for a decent find. By the time you get that one running, correct and titled, you will have the same amount in it and a lot of headache.
IMHO.
You may get lucky and find something under $1000- they are out there, but have cash and be prepared to drop what you are doing and pounce as they go fast.
Hell, you can find a runner for $800 if you're patient. It won't be pretty, but something like a Rebel or Magna usually comes up at about that price range.
This one is dirty as all hell. Would take a lot of work before you could convince me to hop on it.
But you say you have compression, so let's start with the motor.
To test spark, open up the points cover on the right-side of the crank. Pull #3 and 4 plugs and place them in number #3 and 4 boots. Then rest the plugs somewhere on the engine etc such that the threads ground out. Take a flat-head screwdriver and manually open/close the point breakers with the ignition on. It should spark every time you open them. I forget, but one is for #2 and 3 and the other is #1 and 4. So if you test #3 and 4 it should be enough to know we have spark on all four.
If you don't have an impact driver and PB Blaster, get some. Sooner rather than later.
Welcome to the forums! Had a beloved 550f as well!
I hear what your saying buckeye, but it just seems to me there is something to be said about knowing your bike. inside and out.
No doubt about that. Having her fluids and inner workings all over is as personal as you can get :P
But if you get it running, and there doesn't seem to be anything concerning, enjoy it then do a rebuild later.
Thanks Redliner, I will try and get to that this weekend. I have a few pieces of furniture to finish before I can play with my toys :)
I guess the reason I started this thread is because someone posted a 75 cb500T for just $500 today. (guy claims it just needs the front brake gone through) and I was frustrated with the cable snapping last night. I thought maybe I should just buy the 500t and forget about the headache. If only the cb500t didn't look like a turd.... hmm?
Shit, I guess I'm outvoted. Sure, ditch a $200 bike before finding out if it's a runner. Sell it to me for $200.
Bragging about riding a $200 bike that you fixed up yourself* is kinda priceless. The CB160 in the photo to my left was purchased for $100, but it needed a little work.
I'm gonna stick with "see if it runs before you ditch it." Unless you are in the Boston area and do want to sell it to me for $200.
*In discussions with friends and anyone who asks, you never have to tell them how much you put into a bike, simply the purchasing price; thus that bike will always be a $200 bike to you.
That's my thought. I want to do a 2 stage restore. 1. Get it running and learn to ride her well ;) and then maybe over next winter I can strip her down and clean her up right. Unfortunately I Cleveland winters are long, perfect for that sort of thing.
That's more like it. The CB500T is a heavy turd, you're better off without it. Fours are vastly superior.
