ITS NOT ALIVE!!!!! ITS NOT ALIVE!!!!
sxecafe
You think the Carpet Pissers did this?
My Bike '78 cb400t - So... I got home from work all excited to switch out my new indicators after reading replies from you excellent people on how to mount them. I take off the original indicator snip the wires (with the ignition off) and I begin to try and figure out which wire is the ground, b/c both wires are the same, by touching both leads to the new indicator and then turning on the bike with the blinker switch on...nothing with the front. I snip the rear lamps and those work!!! I go back to the front, still nothing. What gives? At this point I look to see if there is a busted fuse, I doubt it cause that wouldn't make and sense being that the other lights are working but just to make sure I start taking them out, finding that nothing is wrong and replacing them from where they came. Just at that point the gauge cluster, the head lamp and all indicators TURN OFF. Pretty pissed at this point. I think its the battery so I test it. 12v FULL CHARGE! What's Going On HERE?!?!?!? I replaced the relay with a brand new one... and I cant think of anything else. HELLLLLLLLLLP!!!!
If all your lights went off at the same time I'd suspect a fuse before anything else. Or a bad primary wire somewhere between that point of the harness and the fuse box.
A lot of aftermarket signals that have two leads and a single filament bulb will have the ground lead grounded inside the housing. This lead has to be connected to ground. An easy way to find which is the power and which is the ground lead coming from your wiring harness is to test it with a multimeter. If the voltage is going from 0V to 12V, you know it's your power. If it's not, check the other lead.
From what I believe, you've blown a fuse for your lighting. Check them again. Automotive fuses are time delay fuses. That means that they take a little bit of time to actually open (blow). This has to do with inrush currents and things that most people don't care too much to know. It's basically a feature that keeps your fuse from blowing from any little thing. So, basically, it just took a little bit for your fuse to blow.
Also, a good and fully charged battery should read more than 12V. Should be closer to 13-13.5V. If you still suspect the battery, check that it still shows a decent voltage with the lights and ignition on. If it's low, like around 5 or 6 volts, you have a bad battery.
