I don't have near the knowledge or talent that many have on here, but from dragging dozens of bikes out of peoples garages and backyards, when it comes to these symptoms, the thing that gave me the biggest payback is throttle shaft seals. many issues can be masked by other issues and it is imperative to get the bike to some kind of base, I.E. getting it to run and make adjustments from there. This is pretty much impossible if the carbs are sucking air from orifices that aren't made for that purpose. The shaft seal is probably the most over looked part of a bike, everybody heads straight for the jets. People will spend days and $ making adjustments and swapping jets etc. Here's the deal, if your bike ran fine with the jets it had, why would it all of a sudden not? Maybe the timing slipped, maybe the valves have finally come out of adjustment to make a difference, or if the change is sudden (fine one day and not the next) a seal is letting in copious amounts of air and screwing everything else up. I used to be that guy, making adjustments when my lack of experience took over. Once I had people show me how a carb. works, I found out, intake and seals were much more common fault than jets... Oh, and friggin needles, learning how to set these also makes life much easier...
