Jetting. CB350 where to start
ubfreakin
You can never have too many!
I just picked up this little bike and need some advise. I have her running and idling fine. Timing is correct, but it runs like crap, will not pull or run smooth. I think with these pipes that jetting is the problem. What is the best jet size to start with? I am at 3650 feet in elevation.
Thanks for any help that is given.
Was timing verified with a strobe light or only checked statically?
Also, please post compression numbers.
Any possible timing and compression issues should be eliminated before messing with the carbs.
You didn't mention it, but pods have waaay more effect on jetting than exhaust. You DEFINITELY have to rejet for pods.
Just an FYI, though, I think you're probably on the correct track with the jetting issues.
It looks like you're running with just headers, which is very suboptimal for most engines. The 350s and 360s prefer a longer exhaust, from a performance stand point.
Being 3000 feet above sea level, you probably want to go down half a step on the jetting, but running headers without mufflers and pods on the carbs will probably want a full step (or even two) richer.
Like I said earlier, though, verify compression before messing with the carbs. It probably wouldn't hurt to double-check the valve clearances, too.
I have 140 psi on the left and 130psi on the right. It does have pods. The pipes are just the headers, but they have a baffle slipped into the end.
"Being 3000 feet above sea level, you probably want to go down half a step on the jetting, but running headers without mufflers and pods on the carbs will probably want a full step (or even two) richer."
What is the stock jetting for this motor? What size would you suggest with the info given.
Thanks again.
Junk the baffles in pipes, they don't work.
Fit long reverse cone megaphone silencers (Norton Commando style or similar)
Cheapo pods cause a shitload of problems, get K&N or Uni or check and modify what you have
This link explains things a lot better about pod problems (just don't ask any questions)
http://www.caferacer.net/forum/technical/19639-pod-filter-thread-geeto.html
You should be able to run stock jetting but YOU WILL HAVE MID RANGE PROBLEM
