Need wiring help!!
Flasher not flashing. What am I missing here? From the battery, the power goes into the fuse block which then goes into one lug on the flasher. The other lug goes to the turn signal handlebar control. If I bypass the flasher entirely and go directly from the fuse block to the turn switch, everything works as it should just no flash. When I introduce the flasher into the system, no lights except the dash indicator. If I switch the lugs around on the flasher, I get nothing (no indicator either).
By the way, got it started yesterday and rode around the block. Getting close...
